Hello,
I am considering buying an Asus RT-N66U to replace my current router. I have my network setup using WPA2-Enterprise, with a RADIUS server configured for dynamic VLAN assignment (as explained in OpenWRT's Introduction to 802.1X.) So, I have a single wireless network, and upon authentication, RADIUS tells the router in which VLAN that particular user should be placed.
I was wondering whether either the stock firmware or Merlin support this setup. I could find some of Merlin's code on GitHub related to dynamic VLAN, but I didn't manage to find any information on whether this kind of setup is supported or not. The reason I'd like to use Merlin instead of OpenWRT or DD-WRT is performance. I do not mind having to perform a few manual steps in the command line.
Thanks,
UPDATE 18-Jun-2017: I did some more looking into the Merlin's code for hostapd (the piece of software running the AP), and it seems like this could be doable if enabling VLAN tagging and if hostapd is compiled with the CONFIG_FULL_DYNAMIC_VLAN option set. I'm trying to determine which options are used for hostapd now. If someone could verify for me whether the vlan_tagged_interface text string appears in the hostapd binary, it would be great help (this is a configuration option available only when full dynamic VLAN support is enabled.)
Thanks,
