eth4: disconnect weak signal strength station ???
JEofMPK
Hardware is XT9’s.
Jul 6 09:31:42 roamast: [EXAP]Deauth old sta in MAC ADDY READACTED
Jul 6 09:31:42 roamast: eth4: disconnect weak signal strength station [MAC ADDY REDACTED]
Jul 6 09:31:42 roamast: eth4: remove client [[MAC ADDY REDACTED]] from monitor list
Can someone help me interpret the above? The router had weak signal? What happen is my phone was far from the main router and I have it bound to it (while the node was in the next room). Woke up and the app wasn’t working. Want to know it its router or phone with the weak signal.
Your phone's signal strength, as seen by the router, fell below the threshold set in the router's roaming assistant and it was therefore disconnected.
Seems to be by design after the latest firmware upgrade. I will put the phone on roam rather than locked in to the base router.
