factory reset still shows device list and dhcp table
Gregh
I have a gt-ac5300 router. I was having some weird issues like not being able to save changes in certain screens. so i decided to do a factory reset using firmware 3.0.0.4.384.81686. I power off the router held the wps button on powered the router on. flashed the firmware with the same firmware and the rebooted again. logged back into the router and the client list was still showing even though the wireless was still at the default so not wireless clients could connect. when i tried to delete a device from the list and save it would not delete. this was the issue i was having before. So i tried the reset again and still the same result. everything else works fine so I suspect the dhcp/device file list is corrupted? I keep seeing this error to in the log that may explain some of this?
May 9 12:05:36 kernel: jffs2: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
May 9 12:05:36 kernel: jffs2: jffs2_reserve_space_gc of 48 bytes for garbage_collect_dirent failed: -28
May 9 12:05:36 kernel: jffs2: Error garbage collecting node at 00bb3cf0!
May
Just not sure how to fix this?
Greg
K-2SO
I've seen the same thing on my RT-AC86U. Use the Reset button instead.
As per Asus both methods do the same thing. As per my experience Reset button is the more reliable method.
Gregh
yea did that one first, should have included that in my post. when that had no effect i tried the wps way second
Gregh
Reset + Initialize from GUI then.
ok went back and did this, no change. I have no reset through the gui, wps and the reset button at least 5 times. I even upgraded to the latest release (which i did not want to do) in hopes that it would erase or clear that file. still no change. I still get the dhcp list of devices even though i have change everything about the network, name passwords etc. only thing i can think of now is to winscp into the router through the Linux Os and manually delete the file but I have not idea how or what the file i need to delete is.
Gregh
People fight with scripts to keep it, you fight to destroy it. :)
What about manually delete the entries? Reset again after, do what you need to do.
doesn't work. when i delete the entry and click apply it just comes backs. If i delete the file and change screens and come back it still there. like i said i cant get rid of it
K-2SO
the router works
People with better NHD platform knowledge may give you advice. Following the history of issues you had with this router I'm guessing you have a corrupted partition. Cutting the power off with your smart plug during operation may have contributed to the problem.
Gregh
yea that was a concern of mine too which is why i posted that question a while back. Most answer did not think it was an issue. but i did start to use the internal schedule and not the smart plug
ColinTaylor
Part of the Furniture
@Gregh I'm not familiar with the filesystem layout of the GT-AC5300. Can you post the output of this command please:
df -h
ColinTaylor
Thanks. We can see that your /jffs partition is 99% full which is causing your problems.
One more thing please, the output of:
mount
Gregh
ok tried the nvram erase and that did not work either. when i go back into the dhcp screen it still shows all the dhcp fixed ip addresses even though the setting is turn off. :(
