It seems some versions of the firmware have an Access Intranet feature for guest networks, and some doesn't.
If it is not a huge amount of effort could this be added into the AC68U builds? I like to use the same SSID for both 2.4 GHz and 5 GHz, so my devices don't need to have multiple settings. But for high bandwidth devices I like to use a different SSID that is only 5 GHz, such as my Roku. The only way I know to add additional SSID's is as a guest network. Without intranet access, some of the features are limited or don't work at all. For example, allowing my Roku to connect to my plex server directly.
