Hello Guys! Just new here.
I really don't know if this is the right place for this thread. So Mr. Moderator I apologize in advance.
Well, I need help and advice in setting up wifi in this building. Here are the parameters.
1. Wifi will be mainly for the 3rd and 2nd floor.
2. The building is around 250 sqm.
3. Rooms are divided by concrete wall.
4. I do not expect the entire area to have very high reception. Just enough for browsing the web, facebook, research and a little bit of youtube. No file transfer, local streaming, network games (LAN and internet) and the likes. (Except)Preferably capable of handling ip cctv cameras.
5. There will be around 50 person spread out inside the building. Aside from their laptops some might have tablets and smartphones eager to connect once signal is detected.
6. At the very least, I am expecting the setup to handle the surge of connections coming in.With minimal or no dropping of connection. This will usually happen during the evening where everyone is expected to be inside the building. By the way the building is a ladies dormitory.
7. People from the 3rd floor will be able to connect on the 2nd floor and vice versa.
8. Simplest, straight forward setup with Least cost and upkeep.
I have 3 setups in mind but I am really not sure if which will work best or if both will really work. Also I am really not sure what specific device (brand and model) should I use.
1st.
Bombard each floor with N300 or N450 access points. Let's say 4-5 in each floor. All in bridge and have one powerful router for WAN and DHCP.
2nd.
Have 2 powerful routers N900 or up in each floor. Both share one WAN and DHCP.
3rd.
Either the 1st or the 2nd setup but each floor has its own WAN and DHCP. (Is it still possible to have same SSID though each floor has its own DHCP???)
1st.
2nd.
3rd.
