I'm using RT-AC56U, after turning on the OpenVPN server1, the following message shows in the "Export ovpn file" field:
But I haven't touch anything else at all, even if I restore all to factory default, then start the OpenVPN server, it's still the same problem...
May I know what it means by error code:0? Is there anything else (such as configure first) before starting the server?
My apology for the dumb questions, I'm new to Merlin firmware, it seems quite a lot of options/settings
Thank you~~
Error when starting the OpenVPN server! Check your configuration and try again. (Error code: 0)
Thank you~~
