How do I capture log events from before a crash on AC66?
e94mli
Is there a way on a rt-ac66 to get the log events from before a crash reboot? Seems log is only stored in ram by default. Was hoping to get a clue to why it reboots.
You can't. Kernel oops messages aren't logged in Syslog, you need a serial cable to capture that output.
Is possible to capture any of the syslog from before a crash in case there is any indication of errors before the actual kernel crash?
No because the syslog is stored on a ramdisk (/tmp) and is saved to only /jffs on clean reboots etc.
That is what I was afraid of. Well I'm going to try the external syslog option, which I just discovered, not as good but much better than nothing. :)
You could save the syslog on an attached USB drive instead of in RAM. It may be different for the AC66, but this is how I do it for my N66U (modify to suit your situation).
/jffs/scripts/post-mount :
#!/bin/sh
logger -t $(basename $0) $1
if [ $1 = "/tmp/mnt/VERBATIM" ]
then
	logger -t $(basename $0) "Moving syslog"
	LOGFILE=$1/syslog.log
	killall syslogd
	cat /tmp/syslog.log >> $LOGFILE
	syslogd -m 0 -S -O $LOGFILE -s 200 -l 7
	mv /tmp/syslog.log /tmp/syslog.old
	ln -s $LOGFILE /tmp/syslog.log
fi
why not just restart syslogd and point it to a thumbdrive same for klogd
klogd should capture most of the kernel messages, but not those that cause the crash, if it's crashed, it's not going to log anything
edit: collin beat me to it, but why not add klogd as well since he wants kernel messages
Since I'm only doing this for debugging I skipped the script and just killed syslogd and started it again pointing to the flash drive. I also restarted klogd to be on the safe side. Remote syslog didn't give any hints hopefully this will. Thanks for the help.
that's correct
but both syslogd and klogd should be killed then restarted
It's doesn't seem to be required (although it's probably good practice). Looking a busybox's klogd.c, it just uses syslog() to write its messages so I don't see it being a problem.
