How to install YAMon / bwmon on Asuswrt-Merlin ?
letgoodgrow
Hello,
I've been searching for a reliable bandwidth monitoring solution, but nothing seems to work.
I'm not sure if the issues are due to limitations imposed by Asus or if the available scripts are just outdated.
Has anyone managed to get a script like that to work effectively?
I've encountered endless loop of errors while trying to install them.
Any help would be appreciated.
I also tried
Have you tried installing dn-vnstat after typing "amtm" within SSH?
Seemed to generally work for me when I tested it not long ago, and mounts a nice WebUI page for the stats.
Not sure what your goal is other than monitoring bandwidth, I saw there was also a Quota Monitoring script from Martineau here: https://www.snbforums.com/threads/edit-real-time-quota-monitoring-download-upload-data-used.50066/
thanks for sharing
| like the built in Traffic Analyzer Stats but its data get wiped randomly and it only show top 5 devices which isn't practical
YAMon shows missing files like setup.sh
I believe that the vnstat script uses vnstatd from Entware, and works independently of the built-in traffic Analyzer:
This is an implementation of vnStat for use on AsusWRT-Merlin routers. This effort was started to enable accurate measurement of data use in a local database (for privacy reasons), and as an alternative the internal monitoring tool, Traffic Analyzer > Traffic Monitor, which will periodically record false “17GB” usage bursts.
We can't really help without seeing what your trying to do or the messages your getting.
Please provide the steps your following and any screenshots where you get stuck.
FWIW it used to work seven years ago. :)
vnstat does not show stats like devices etc..
a part from that, I tried to install bwmon
I installed Entware through "AMTM"
then followed all the steps here
but when it come to viewing the html page it doesn't open
I checked on ssh :
ps | grep lighttpd
31342 admin 3328 S grep lighttpd
then checked:
ls /opt/share/www/bwmon/index.html
: No such file or directory
Try ls /opt/share/www/bwmon/
nice that one shows results, thanks for help
next: I tried
netstat -tuln | grep lighttpd
no results, ai says it means means Lighttpd isn’t listening on any port
so we made
lighttpd.conf and filled with some data inlucde the port 8081
and tried to start
killall lighttpd 2>/dev/null
lighttpd -m /opt/lib/lighttpd -f /opt/etc/lighttpd/lighttpd.conf
but failed
@RT-AX58U-8338:/tmp/mnt/ym/entware# lighttpd -m /opt/lib/lighttpd -f /opt/etc/lighttpd/lighttpd.conf
2025-06-24 00:57:13: (plugin.c.232) dlopen() failed for: /opt/lib/lighttpd/mod_indexfile.so /opt/lib/lighttpd/mod_indexfile.so: cannot open shared object file: No such file or directory
2025-06-24 00:57:13: (server.c.823) loading plugins finally failed
next try
opkg update
opkg install lighttpd-mod-indexfile
2025-06-24 01:04:25: (plugin.c.232) dlopen() failed for: /opt/lib/lighttpd/mod_indexfile.so /opt/lib/lighttpd/mod_indexfile.so: cannot open shared object file: No such file or directory
2025-06-24 01:04:25: (server.c.823) loading plugins finally failed
x_asus@RT-AX58U-8338:/tmp/mnt/ym/entware# opkg update
Downloading https://bin.entware.net/armv7sf-k3.2/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
x@RT-AX58U-8338:/tmp/mnt/ym/entware# opkg install lighttpd-mod-indexfile
Unknown package 'lighttpd-mod-indexfile'.
Collected errors:
* opkg_install_cmd: Cannot install package lighttpd-mod-indexfile.
next: I tried
so we made
and tried to start
but failed
next try
opkg update
Your problem is the installer for bwmon is not completing.
I am assuming your only getting this far when trying to install:
Instead of this:
Which is why I mentioned to include any messages your getting and any screenshots.
To fix it, modify the install.sh at this location:
/mnt/USBNAME/bwmon/server
Open the install.sh and modify this code at line 38 :
bc -v > /dev/null 2>&1
if [ $? -ne 0 ]; then
    echo "Installing bc ..."
    opkg install bc
else
    echo "bc is installed"
fi
To this:
if ! bc -v >/dev/null 2>&1; then
    opkg install bc
else
fi
And the install will complete.
Instead of this:
    opkg install bc
else
fi
To this:
    opkg install bc
else
fi
brilliant, your screenshots was identical to what I saw
but although I got the same results after editing and running
./server/install.sh
the html page show
404 not found
btw the bwmon seems to open the html page only on LAN not WAN but that won't matter unless it works first
./server/install.sh
the html page show
404 not found
Looks like you haven't configured the lighttpd. Did you follow these instructions from the installation process?
I don't see a port in your screenshot and it's not clear if you followed the additional configuration steps after the install. If you did, then specify the port number.
Your screenshot shows: 192.168.50.1/bwmon but if you configured the port to be 8989 for example, it needs to be 192.168.50.1:8989/bwmon
you're right
I the picture was the output of this link
http://192.168.50.1:80/bwmon/index.html
then when I set port to 8080 and even 8081
http://192.168.50.1:8080/bwmon/index.html
the browser show : [this site can't be reached
here's the content of lighttpd.conf :-
server.modules = (
"mod_access",
"mod_alias",
"mod_redirect",
"mod_indexfile",
server.modules_path = "/opt/lib/lighttpd"
server.document-root = "/opt/share/www"
server.port = 8080
index-file.names = ( "index.html" )
mimetype.assign = (
".html" => "text/html",
".css" => "text/css",
".js" => "application/javascript",
".png" => "image/png",
".jpg" => "image/jpeg"
trying to restart
and install
opkg update
you're right
trying to restart
and install
opkg update
The installer for bwmon is buggy. In your case above, It's not installing the entware package for lighttpd because it finds the built-in version.
But we require the Entware version installed for bwmon to function.
Do:
Then once installed, edit this file /opt/etc/lighttpd/lighttpd.conf
With the port of choice. My example can be found below:
server.modules = (
"mod_access",
"mod_alias",
"mod_redirect",
"mod_indexfile",
server.port = 81
mimetype.assign = (
Then restart both the newly installed lighttpd and bwmon with the below commands:
bwmon:
/opt/etc/init.d/S80bwmon restart
lightttpd:
/opt/etc/init.d/S80lighttpd restart
Then you can access bwmon from the port of choice like this: http://<your_router_ip>:<lighttpd_port>/bwmon
it seems that there's two files
lighttpd.conf
lighttpd.conf-opkg
I edited the same content for both based on what you showed me but nothing has changed
You only care about lighttpd.conf
Edit the port number and make sure to restart the services afterwards.
