I am looking to spread WiFi though out my property, Would these units I linked to work?
JOE.G
Hi, I have a large country property, I would Like to have WiFi on a few of the acres around my home and shop. I have 2 2.4 G Nano stations that are hooked to house router and then to a Router set up as a AP in the shop I usually mostly 5 G around here.
Would either of these options work? Are there better choices? How would I hook them up? Can they get hooked to either router?
Is here one that is better then the other? If i kept my 2.4 Nanos can I use the 5G Unit below? Thank you
https://www.amazon.com/dp/B00M77MWHI/?tag=snbforums-20
https://www.amazon.com/dp/B004EHSP3Y/?tag=snbforums-20
https://www.amazon.com/dp/B00HXT8R2O/?tag=snbforums-20
Greg72
You would need an antenna on various buildings as backhaul so that you can better cover the property with exterior AP’s.
thiggins
Mr. Easy
Staff member
What's wrong with your current setup using 2.4 GHz Nanos? What sort of distances are you trying to bridge and do you have clear line-of-sight.
JOE.G
The Nano stations contact just fine, I am just trying to spread WiFi though out parts of the property, I wasn't sure if there was a unit I could use to do that . Or do I need to put Nano stations on each building?
