loopdemack
I have a question about ixchariot, I want to make a test on the TP-link tl-wr941ND using the ixchariot.
100mbit wan-to-lan and vice versa environment.
Both network cards connected to wan and lan were 1gbit, but they are both selected in a 100mbit full duplex.
When I measured the total simultaneous connections using a higher number of pairs, I get some strange error about the timing, tell me which timing did you selected when you tested routers on the 100mbit network wan/lan.
And which script did you selected, and which quality of service did you used in the ixchariot, and did you changed(altered) something in the script.
And did you altered anything in the ixchariot basic settings, I'm using IXchariot 6.7.
The error was:
Error: 'CHR0336: A timing record was received with a measured time between 1 and 20 milliseconds.'
Tell me how do you know that you reached the maximal amount of total simultaneous connections, how could I recognize when I reached the pairs limits?
I did read your explanation, http://www.smallnetbuilder.com/content/view/26563/53/
but could you explain a little bit more. Thank you.
Could you explain me how could I tweak the timing that I could make a good environment for the 100mbit test, I want to overcome that error that I got.
I found in a http://www.ixiacom.com/support/ixchariot/knowledge_base.php ixchariot knowledge base about this error but they didn't told how to set timings according to network speed.
The Router I'm testing is TP-Link tl-wr941ND Atheros chipset MIMO
CPU: Atheros AR9132-AC1E 400MHz
Switch: Marvell 88E6060-RCJ1
Memory: HY5DU561622FTP-5
Flash: SPANSION FL032A1F
Radio: AR910
I want to find max number of pairs on this router.
The error was:
Radio: AR910
