Installed Wrong Version on RT-AX88U-Geez
Louis James
Good Morning:
Feeling kinda dumb this AM. I accidentally installed the RT-AX88U Pro V.388.2.2 on my RT-AX88U (not pro). When I realized my mistake, I installed the correct RT-AX88U V.3.88.2.2 and everything "seems" to working correctly. Wondering if anyone has any thoughts? Thank you for helping.
Louis
Did you confirm that it actually installed the wrong version by looking at the model number shown in the GUI? Normally the router will silently reject a firmware for a different model.
That's the strange part. After install, I saw that it said Firmware 388.2.2. I ONLY realized what I think was a mistake based on the ZIP file that I downloaded that said "RT-AX88U_PRO_388.2_2.zip" not RT-AX88U_388.2_2.zip. I can only assume that I installed the wrong Firmware. HOWEVER, you would think that either it would not have installed or it would have "bricked" the router.
Seemingly, all is well, but I have no way to know if I acted stupidly. Geez.
Louis
If you've installed the correct version I would do a couple of resets, so no information from the wrong FW is left over.
