Is there anyway to redirect 192.168.2.1 and router.asus.com to my DDNS fearz.asuscomm.com?
I can't seem to secure https://192.168.2.1 nor https//router.asus.com
Is there anyway to redirect both to fearz.asus.com <- its the ony URL that uses HTTPS without warning
I did manage to get it to work... but, on the PC/VM i want my xxxx.asuscomm.com to work with HTTPS inside my network and get it secured, i entered a hosts entry to point xxxx.asuscomm.com to my Router IP, so from within my network just access with the xxxx.asuscomm.com as from the outside, same thing, works inside and out... no need to used the ip anymore with this, and router.asus.com, i only used this once to setup the router initialy, once i get my certificate from let's encrypt, i do what i explained here... and all is golden with this workaround.
