iamclaus
I recently acquired a vinyl cutter and on a whim thought I'd cut some decals to cover the fronts of the D6 disk trays in my DS418play, shared the result with others and figured I'd share the result here, too. The decals don't really serve any purpose beyond being a novelty, and I just like orange and black.
If you'd like a set for yourself, head on over to my Etsy store. I can make them in a few different colours, and change the text or add other artwork. I'm open to ideas.
Again, these are only meant to fit the flat-front D6 drive trays like those found on the DS418play and other models. I don't currently have access to any other tray sizes or types.
And yes, I know the numbering should or shouldn't start at 00, so you get to choose either 01 or 00 to match your preference.
