IronSchramm
I apologize in advance as i'm sure i'm using the wrong termonology and everything, i'm very new to adding scripts to FW's. I've been running custome device firmwares for years, but add-on scripting is new to me.
Anyways a few weeks (maybe a month) ago someone posted a script designed to cut down traffic from iOS devices. I added that script to my Asus RT-87u running the latest version of Merlin at that time. I have since installed the latest 380_67 beta 1. And have flashed most of the stable firmwares released during that time frame. I want to know how to check to see if that iOS traffic script is still running and how to remove, or did flashing the updated firmwares have done that for me? I do not typically factory default the device between each firmware.
The reason I want to remove that script is i've actually ran into a few issues with iOS devices through out my home and i'm not sure if that script is possibly the cause. For instance, I purchased an apple watch, it has the ability to unlock my iMac, but it must go through a registration process to do that, it cannot complete that process at all. I've gone through every tech article i've found to verify it should work but it's not. The registration process requires all three devices, iMac, iPhone and Watch are on the same wifi network (they are) and it must connect to Apple services to authenticate the first time, that process times out.
Also Siri on our iOS devices is quite slow to aquire query results, if i'm on LTE (which is MUCH slower than my home fiber) Siri is almost instantanous in it's results.
Basically how can I remove that script or check if it's still running, thanks.
