Mesh main reboot, does it reboot all the nodes?
snovvman
With a mesh of AC86Us, when I reboot the main mesh node, do the other nodes also reboot? I find that sometimes the device will no longer connect to the WiFi at all, requiring a reboot. Sometimes the culprit is one of the extension nodes. I usually just power off/on all the devices so I haven't collected enough data but wonder if I trigger a reboot from the main node, all the other nodes will reboot? Thanks.
An AiMesh System reboot from the router webUI is suppose to reboot all nodes, but you should always confirm each node comes up healthy. broadcasting all signals.
OE
