azazel1024
So, my next router is deffinitely a C7 Archer. Between price/performance it seems like a beast. Combined with upgradable external antennas, for 5ghz at least, its a win.
My question is, anyone think on or actually modify the 2.4Ghz internal antennas to external removable ones? It looks like the current antennas are attached through soldered pigtails. So...for replacement, I'd assume you'd need to yank the connectors on an external antenna set with u.fl connectors on it, and then solder the wires directly to the board, and then mount the RP-SMA connectors probably using washers or something (or super glue?) to the chasis after drilling holes for them.
The internal antennas actually don't look all that tiny, but I'd assume they are less gain than even piddly 2dB omni's, let alone the 5dB suckers used for the 5Ghz radios.
Or 8dB antennas all the way around!
Doesn't seem like a project worth taking on anytime soon, as I don't know that I have a need to do it, in part because it'll be replacing a Netgear 3500L, which probably has similar or lower 2.4GHz performance, and I am more than happy with the 2.4GHz performance in my house (well, when running the two 3500L I have at either end of the house).
I am thinking long term though and I want coverage in part of my yard. Right now I am installing a TL-WR849nd in my garage and mounting the antennas right below the eves of the garage roof with some RP-SMA 3' cables. That likely should cover things at the moment. Long I am razing and rebuilding a shed near the corner of my property as a shed/studio and I'd move the AP location out there (a little closer to where I want coverage). Having both 5GHz 11ac and 2.4GHz 11n coverage as wide as can be wouldn't be a bad thing and I can only assume that the C7 will get cheaper and cheaper over time.
