Namecheap DDNS updates insecurely over http
kayson
I'm on 384.3 on an RT-AC68U. I just set up ddns with my namecheap domain, but according to the logs, it appears to send the request over http, not https.
May 23 11:48:10 start_ddns: update WWW.NAMECHEAP.COM namecheap, wan_unit 0
May 23 11:48:10 ddns_update: ez-ipupdate: starting...
May 23 11:48:10 ddns_update: connected to dynamicdns.park-your-domain.com (104.219.249.157) on port 80.
May 23 11:48:11 ddns_update: request successful
May 23 11:48:11 ddns_update: asusddns_update: 0
May 23 11:48:11 ddns: ddns update ok
It appears that the server does in fact support ssl: https://dynamicdns.park-your-domain.com/getip
I'd rather not send my api key insecurely, since it would allow anyone to point my domain to their own server. I guess I can either do a custom ddns script, or use a software client. Or maybe it's fixed in the latest release? (A project for later today, I suppose).
Can this be fixed?
Thanks. I figured that was the case. Do you know if there's a way to modify the built-in?
No, because ez-ipupdate does not support SSL.
