I have a version compiled for Win10. Problem is that it doesn't run properly. I don't have the skills to debug it.Someone would have to build it for windows, and the code there is very old, not sure how this would play with Win10
Win10Pro with WSL - iperf, netperf, and flent are available there if this helps...
I've never used WSL myself but I would assume that the installation procedure for netperf would depend on which distro you installed.I have a system set up with WSL, but didn't know I could install those apps. Can you provide some tips?
Thanks, but no. Has to be netperf since I'm trying to use flent.
I've been trying so many things, I forgot that I did install iperf3 and netperf (I'm running Ubuntu 18.04 via WSL). The problem is that I want the WSL Ubuntu to use Intel AX200 Windows drivers, which work, instead of the Linux drivers, which don't. WSL doesn't do that.
Thread starter | Title | Forum | Replies | Date |
G | Multiple tries needed to open windows share | Other LAN and WAN | 0 | |
S | Help! Network discovery won't stay on / can't start DNS Client service (Windows 11 Home) | Other LAN and WAN | 17 |
Welcome To SNBForums
