Network map Tx and Rx figures
theboz
Hi.
I noticed several connections on the list of connections under asuswrt-Merlin, whose Tx and Rx numbers continually change. These are short term changes - seconds apart. Why would this be happening, and does it indicate a problem?
I’m using an RT-X3000.
TIA
Because the Wi-Fi environment is shared and always changing. This is normal and doesn't indicate a problem.
Hi.
TIA
Power management. This is normal.
Ah, yes - power management too. Some mobile devices may drop to 1-6-24Mbps in power saving mode. Examples:
