A friend is having a new stick-built house in a gated community. Inside one garage wall, they have installed a small covered opening. Inside this box is the telco and cable tv wiring. Each room has two cable tv outlets and one ethernet port. His cable tv company will provide him with cable internet access. I am only concerned about the internet part of this.
There is not room inside this wall-box for anything, so there will be a small shelf that will hold his cable modem. My friend does NOT want his wifi router located in the garage, but he also wants the ethernet ports to work in each of the rooms. He wants the wifi router to be in his office, not in the garage.
I am not familiar with this at all. How will DHCP work - basically, what does he really need so to make this work with the router in his office inside his house and the cable modem and all the ethernet cables going to all the rooms all coming to this wall-box in the garage?
The only thing I could think of was to put an ethernet switch in the garage with the modem and then plug the cables into it and then in his office he can have his wifi router, but how would this be configured for DHCP, etc? He wants his router in his office so he doesn't need to go to the garage should he need to reset it.
Thanks,
Bob
Thanks,
Bob
