No Daily Stats In Traffic Monitor on N56U
bobpow
I installed the latest version of stock firmware 376.3637 and did a reset as instructed 2 days ago on my N56U but there are no daily stats .. the real time and 24 hr stats are working fine. I searched around the site and didn't see anything. Any one have any ideas?
i also been using N56U and i still using 3.0.0.4.376_1665
the daily stats still there
traffic manager -> trafic monitor -> in right area there are drop down box
u can select realtime - hourly - daily
not sure if asus remove it with version 376.3637
Fixed in New Firmware
I had the same issue and just upgraded to the latest firmware: 3.0.0.4.376_3754
And the problem is resolved now. Also the Traffic monitor has the tab for "Internet" again as well.
I also did settings-reset to default on the router before upgrading the firmware and manually re-entered all of my settings before upgrading. I don't know if that helped or not.
Hopefully it works for you since this new firmware also resolves the big LAN-side security issue.
-Morgan
