I don't seem to have that problem. It comes right up for me. It cycles through all the options instantly. I even used the same settings you were trying, @Khadanja ...I'm in the same boat. All other tabs look ok to me, just this Compare Usage shows "No data to display" when on Days interval. Works fine for Weeks.
There is this topic with some clues but it seems like a different issue overall: dn-vnstat "no data to display" in "Data usage" and "compare usage" | SmallNetBuilder Forums (snbforums.com)
I have my vnstat DB files available to share - in case it's a data anomaly.
Just can't upload here, the forum won't allow me.
Not sure how much assistance you'll be able to get to fix something so specific like this... your best bet might be to uninstall/reboot/reinstall... the only downside being, you'll lose all your previous stats.I suspect I may have some data corruption.
In any case, I'll need assistance to fix it.
I didn't see any inconsistencyTime,rx,tx
1654338600,329590,73962
1654338300,170295,86602
1654338000,653803,164939
1654337700,1665666,297552
1654337400,461336,126710.
sqlite3 /opt/var/lib/vnstat/vnstat.db "select * from day" >> db_out_day.txt
sqlite3 /opt/var/lib/vnstat/vnstat.db "select * from hour" >> db_out_hour.txt
sqlite3 /opt/var/lib/vnstat/vnstat.db "select * from fiveminute" >> db_out_fiveminute.txt
The series goes from 21:35 to 1:20.91|1|2022-05-31 21:25:00|14755877|3161144
92|1|2022-05-31 21:30:00|1853734|470504
93|1|2022-05-31 21:35:00|4652414|556729
94|1|2022-06-01 01:20:00|837735|205633
95|1|2022-06-01 01:25:00|557067|239716
96|1|2022-06-01 01:30:00|87197|56802
Goes from 21 to 1 o'clock.7|1|2022-05-31 19:00:00|74135041|8303662
8|1|2022-05-31 20:00:00|40981648|4356013
9|1|2022-05-31 21:00:00|32886089|5789282
10|1|2022-06-01 01:00:00|3513629|1103676
11|1|2022-06-01 02:00:00|12761162|3258084
12|1|2022-06-01 03:00:00|92374819|5389951
1098|1|2022-06-04 13:10:00|461336|126710
1099|1|2022-06-04 13:15:00|1665666|297552
1100|1|2022-06-04 13:20:00|653803|164939
1101|1|2022-06-04 13:25:00|170295|86602
1102|1|2022-06-04 13:30:00|329590|73962
1103|1|2022-06-05 13:20:00|306271|190422
1104|1|2022-06-05 13:25:00|854139|234211
1105|1|2022-06-05 13:30:00|120444|32123
Jun 4 13:33:03 vnstatd[3778]: SIGTERM received, exiting.
Welcome To SNBForums
