Hi to everybody,
I have plugged a USB External 1TB disk to my router RT-AC68U and log file show me following error information about NTFS funciona:
Sep 13 07:05:24 asusware: re-mount partition /dev/sda1...
Sep 13 07:05:24 disk_monitor: re-mount partition
Sep 13 07:05:24 usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Sep 13 07:05:25 usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/K-HOME.
Sep 13 07:05:25 asusware: done.
Sep 13 07:05:25 disk_monitor: done
Sep 13 07:06:05 kernel: tntfs error (device sda1, pid 2619): ntfs_ucstonls(): Unicode name contains characters that cannot be converted to character set utf8. You might want to try to use the mount option nls=utf8.
warning (device sda1, pid 2619): ntfs_dir_emit(): Skipping unrepresentable inode 0x4a6e.
Sep 13 07:06:07 kernel: tntfs error (device sda1, pid 2621): ntfs_ucstonls(): Unicode name contains characters that cannot be converted to character set utf8. You might want to try to use the mount option nls=utf8.
Sep 13 07:06:07 kernel: tntfs warning (device sda1, pid 2621): ntfs_dir_emit(): Skipping unrepresentable inode 0x4a6e.
Sep 13 07:06:13 kernel: tntfs error (device sda1, pid 909): ntfs_attr_update_mapping_pairs(): Failed to determine the size for the mapping pairs (error 22).
Sep 13 07:06:13 kernel: tntfs error (device sda1, pid 909): ntfs_write_inode(): Failed (error 5). Run chkdsk.
Sep 13 07:10:02 kernel: klogd started: BusyBox v1.25.1 (2017-08-18 17:39:32 EDT)
What can occours?
Other errors about Download Master:
S50downloadmaster.1 start
Sep 13 07:05:43 transmission-daemon[2453]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:380)
Sep 13 07:05:43 transmission-daemon[2453]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:84)
Sep 13 07:05:43 transmission-daemon[2453]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:95)
Any clears?
Thanks !!!
What can occours?
Any clears?
Thanks !!!
