Hi Eric,
i have issue with openvpn server on 3.0.0.4.220.17.
The issue is i cant set openvpn to start with WAN. Even if service is set to ON or OFF I set "Start with WAN" on YES and then hit apply and over and over again is going back to NO. Also i have te same with "Respond to DNS" option. Cant' make this work and save. Manual start of openvpn server service works well...
I clear the system log then set start with WAN on YES and this is output(maybe I doing something wrong).
above this issue openvpn works well and connecting clients... THX for your support...
Sep 22 19:34:30 notify_rc : restart_vpnserver1;restart_dnsmasq
Sep 22 19:34:30 openvpn[816]: TCP/UDP: Closing socket
Sep 22 19:34:30 openvpn[816]: /sbin/route del -net 10.8.0.0 netmask 255.255.255.0
Sep 22 19:34:30 openvpn[816]: Closing TUN/TAP interface
Sep 22 19:34:30 openvpn[816]: /sbin/ifconfig tun21 0.0.0.0
Sep 22 19:34:30 openvpn[816]: SIGTERM[hard,] received, process exiting
Sep 22 19:34:30 kernel: tun: Universal TUN/TAP device driver, 1.6
Sep 22 19:34:30 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Sep 22 19:34:30 kernel: device tun21 entered promiscuous mode
Sep 22 19:34:30 openvpn[854]: OpenVPN 2.2.2 mipsel-linux [SSL] [LZO2] [EPOLL] built on Sep 17 2012
Sep 22 19:34:30 openvpn[854]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sep 22 19:34:30 openvpn[854]: Diffie-Hellman initialized with 1024 bit key
Sep 22 19:34:30 openvpn[854]: TLS-Auth MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sep 22 19:34:30 openvpn[854]: Socket Buffers: R=[87380->131072] S=[16384->131072]
Sep 22 19:34:30 openvpn[854]: TUN/TAP device tun21 opened
Sep 22 19:34:30 openvpn[854]: TUN/TAP TX queue length set to 100
Sep 22 19:34:30 openvpn[854]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Sep 22 19:34:30 openvpn[854]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Sep 22 19:34:30 openvpn[854]: Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Sep 22 19:34:30 openvpn[864]: Listening for incoming TCP connection on [undef]:1194
Sep 22 19:34:30 openvpn[864]: TCPv4_SERVER link local (bound): [undef]:1194
Sep 22 19:34:30 openvpn[864]: TCPv4_SERVER link remote: [undef]
Sep 22 19:34:30 openvpn[864]: MULTI: multi_init called, r=256 v=256
Sep 22 19:34:30 openvpn[864]: IFCONFIG POOL: base=10.8.0.4 size=62
Sep 22 19:34:30 openvpn[864]: MULTI: TCP INIT maxclients=1024 maxevents=1028
Sep 22 19:34:30 openvpn[864]: Initialization Sequence Completed
Sep 22 19:34:30 dnsmasq[770]: exiting on receipt of SIGTERM
Sep 22 19:34:31 dnsmasq[868]: started, version 2.55 cachesize 1500
Sep 22 19:34:31 dnsmasq[868]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP TFTP
Sep 22 19:34:31 dnsmasq[868]: asynchronous logging enabled, queue limit is 5 messages
Sep 22 19:34:31 dnsmasq-dhcp[868]: DHCP, IP range 192.168.1.2 -- 192.168.1.10, lease time 7d
Sep 22 19:34:31 dnsmasq[868]: read /etc/hosts - 3 addresses
Sep 22 19:34:31 dnsmasq-dhcp[868]: read /etc/ethers - 7 addresses
Sep 22 19:34:31 dnsmasq[868]: using nameserver 62.179.1.62#53
Sep 22 19:34:31 dnsmasq[868]: using nameserver 62.179.1.63#53
