keeps my bssload within 20%
This is not how Wi-Fi works. The channel is not for your exclusive use and Channel Utilization is not in your control. What you did with 802.11ax only is severely limiting the compatibility, high minimum basic rate is severely reducing the range, 40MHz channel bandwidth is additionally reducing the range plus increasing interference for almost the entire band. Your Wi-Fi is basically incompatible with >90% of currently available IoT devices and potentially increasing the noise floor for everyone else around you.
So you only need to reduce the MCS by a few levels to offset the extra 3db. The doubled bandwidth is more than enough to offset the throughput loss from reducing the MCS index. It looks like you never consulted https://mcsindex.net.4 - ~3db signal level difference
Who says I don't care about range? I just don't care about excessive coverage that serves no purpose.Okay, different question for you - if you don’t care about range and compatibility and all your clients are with minimum AX support… why you even have 2.4GHs radio enabled? Home routers still offer 2.4GHz band exactly for range and compatibility, no?
Welcome To SNBForums
