HumanPanda24
Hi Merlin users,
Can someone confirm the following for me. I am using an RT-AC3200 with 384.5
My setup is the RT-AC3200 is being used in AP mode.
Smart Connect Setup for the main SSID.
Then I have 3 guest networks, one for each band such as
SSID_2G
SSID_5G_1
SSID_5G_2
This would have the same passphrase as the main SSID.
This is for some stuff like the Echo which does not like Smart Connect or if I want a device to only connect to a certain band.
With this setup it works 100%. The problem is however if I setup another guest network as we are allowed to have 3 per band.
The 2nd SSID would be
SSID_guest and has a different passphrase so I can give it to guests and change it later. The second I add this 2nd SSID the 2G band stops working. This 2nd SSID can be on any band but, it still breaks the 2G band. The 5G bands however still work. The SSID shows but, when you try to connect it fails.
I see this on all devices such as my phone which is Dual Band connect to SSID_2G and even devices that only have 2.4Ghz try to connect to either the main SSID or SSID_2G. The moment I take it off the issue still occurs but, if I take it off and then take off SSID_2G and renable it, it works again.
Can someone with an RT-AC3200 with 384.5 please confirm for me?
Edit: This did not happen before I updated to the latest firmware. It was working for ages before then. I forgot what version it was though.
I have also done a factory reset and initialize and the issue occurs right when I add the 2nd guest SSID.
SSID_2G
SSID_5G_1
SSID_5G_2
