Possible to disable constant DNS checks to dns.msftncsi.com?
Is it possible for you to do a reboot and check again? Are you using dnsmasq logging for monitoring?
I'm curious about the dns_probe_timeout parameter; as this thread's author reported having around 40k+ probes per month, which correcponds approximately to a single probe each minute just like you reported.
Could you confirm what's the current value of the parameter in your router right now and after a reboot (if possible)?
nvram get dns_probe_timeout
Still pinging at 1 minute intervals. Monitoring via Pihole.
nvram get dns_probe_timeout shows 2 (both router and node).
The timeout only influences how long it waits for a slow dns response, not the interval between queries.
It’s also possible the conn_diag process is calling the same wanduck function. Even if you try to kill it, watchdog will restart it.
I would just try to append the entry to the local hosts file on the router/AP.
131.107.255.255 dns.msftncsi.com
I haven't seen any constant pings in the last 12 hours since changing to localhost - hopefully that means it fixes things. Still not a good solution for everyone else with the issue though.
Really seems AP mode should completely disable this.
dns.msftncsi.com is a Microsoft domain. It's Windows machines doing the lookup, not the router.
Redirecting to local ip will make Windows think it's connected to internet even when your router has lost internet connection, that's all.
This is incorrect. The router also uses this hostname to test whether DNS resolution (and by implication internet access) is working.
I stand corrected, you are right - weird that a Linux based router uses a Microsoft domain to test internet.
Asus probably chose this because that remote server is specifically designed for that purposes, and it`s also less likely to be impacted by ISP or upstream firewalls.
You don`t want to DDoS a random remote site by having 250,000+ routers constantly pinging it. Ask D-Link about their past NTP abuses for example... They hardcoded some random NTP server which was never intended to support the load of all of D-Link's router owners, crushing that server.
Kind of like how TP-Link hardcoded a bunch of their stuff to a JP server. Only just discovered this when I found the whole Asus issue. They didn't feel the need to patch the older revision of the device I had, so I bought a newer version.
It's also unfriendly that Asus routers use pool.ntp.org as the default time server without abiding by the NTP pool vendor guideline for a dedicated hostname.
Interesting, I wasn't aware of that. I feel like a large number of products out there do use pool.ntp.org as the default.
EDIT: I just checked out of curiosity, and QNAP also uses pool.ntp.org.
I use time.nrc.ca on my own router. Old habit of mine.
I have also wondered why my ISP doesn't contribute to the ntp pool. A Stratum 1 server is basically just a GPS receiver, not expensive. Then they could also serve their customers with an accurate time.
My TP-Link wifi range extender constantly contacts:
a.root-servers.net
Diversion allows this connection and from research, there isn't a way to stop this activity other than getting rid of the device, however, this device works well as intended.
Is there no way to reduce the frequency of the pings to dns.msftncsi.com?
Rather than disabling the feature altogether, is there a way to reduce the frequency? In my case it occurs every minute from the node.
@RMerlin
This discussion kept circulating in my mind for some time now, and I got an idea that might provide a solution for anyone looking to decrease the hard-coded frequency of DNS Probing.
@Avrution
nvram set dns_probe_host=localhost
Just don't blame me when your router doesn't recover from genuine internet outages or when dual wan doesn't work. ;)
What if we set a custom TTL value for the DNS host being probed every minute, to a value of like a minute and a half. Wouldn't this make dnsmasq skip half of the DNS probes that the firmware do every minute?
This way a user might be able to control the hard-coded interval of DNS probes. For instance, if someone wants a DNS probe interval of 5 minutes, they can set a TTL value of 4.5 minutes.
Please correct me if I'm wrong.
Don`t mess with a system intended to properly detect if your WAN is up or not.
I agree.
But this thread was originally about completely disabling it for a setup that doesn't need internet detection such as AP Mode (which was solved by @ColinTaylor already), or the need to lower the frequency of DNS probes on demand, for some rare cases where there's a limited DNS lookup quota, or any other reason or limitation.
I'd appreciate any help with the idea I came up with.
By default, all the router's own DNS lookups go directly to the WAN DNS servers, bypassing the local dnsmasq instance. The option for the router to use the local dnsmasq was completely removed in 3006 firmwares.
Very accurate, I totally missed this point.
And this functional change make it impossible now, I believe.
Thank you, case closed!
