gkasica
I've got the VPN up and it works beautifully from away from the local network or via LTE cellular,
I'm curious to know if you can make any changes to the login process or script it seems to use to also allow it to connect while on the Local LAN/WiFi? It's not a huge issue but if I could get it to work both ways that would be ideal. Is there any sort of documentation on how the OpenVPN Script works/syntax/etc.??
Thanks!
George Kasica
gkasica@netwrx1.xom
Thanks!
George Kasica
gkasica@netwrx1.xom
