88keyz
I don't know if its even possible but if anyone out there knows of a good walk-through tutorial on how to setup the stock firmware on the R7000 for a Hurricane Electric/TunnelBroker 6in4 IPv6 tunnel I would appreciate any help you can provide. Using stock firmware 1.0.4.28 in case that helps or matters.
I've setup TunnelBroker IPv6 tunnels on other routers (OEM, Tomato, DD-WRT) but I can't seem to figure out the setup on the R7000. Nothing I try seems to work so I'm beginning to think its not possible. I realize I could flash DD-WRT or Tomato onto the R7000 but I've found that my wireless range isn't as good with third party firmware. In addition without the CTF hardware acceleration I can't max out the downstream my 300D/20U internet connection so I'm really looking for a solution using the stock firmware.
Thanks in advance for any help or suggestions you can provide.
