Hello.
1st off I would like to thanks Voxel and Kamoj. I am new to Linux, so please bare with me.
I am on V1.0.2.80.4SF and have been having issues with internet speed when using OpenVPN (IPVanish). I have 2 devices connected and every report the same speed.
I get 30 - 35 mbps while using IPVanish on the routerand on a mobile device.
If I disable it I can get upto 250 mbps (i have comcast at 300+ )
the thing is, that when I run the IPVanish application on win10, I get close to 220 mbps. (this make my head hurt )
at this point I do not know for what else I need to look for and or change.
this is the .opvn:
client
dev tun
proto udp
remote iad-a03.ipvanish.com 443
resolv-retry infinite
nobind
persist-key
persist-tun
persist-remote-ip
ca ca.ipvanish.com.crt
verify-x509-name iad-a03.ipvanish.com name
auth-user-pass IPVanishVPN.auth
comp-lzo
verb 3
auth SHA256
cipher AES-256-CBC
keysize 256
tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-DSS-WITH-AES-256-CBC-SHA:TLS-RSA-WITH-AES-256-CBC-SHA
I did compare the logs when I connect via router with ipvanish enabled and running IPVanish thur app.
i did notice that snd and Rcv buffers were a bit different, but i have not found any why to actually change it.
I did change it in the /etc/init.d/openvpn-client file but that did not help.....
any way I thank everyone in advance for taking a look....
Senpai
this is the .opvn:
client
dev tun
proto udp
nobind
persist-key
persist-tun
persist-remote-ip
comp-lzo
verb 3
auth SHA256
cipher AES-256-CBC
keysize 256
Senpai
