Router bricked? AX88U
surgeonbyday
Hey Guys,
I have an AX88U which I updated to the latest firmware today. Now, the thing wont start up completely. The WIFI lights are on, the power light is on, and a red internet light is on. The USB lights will come on when a USB device is plugged. THe Ethernet light will not turn on if connected to PC via LAN. The wifi does not broadcast so I cant connect to it. Also, the reset button on the back does nothing. Any ideas? I hope this thing isnt bricked!
Jeffrey Young
Make sure you had the correct firmware, then use the rescue utility (https://www.asus.com/support/FAQ/1000814/) or the router's internal web server (available at 192.168.1.1 once the router is in rescue mode) to reflash the router.
EDIT: My bad @surgeonbyday . I misread your post as your router being 100% unresponsive in every way. Glad @ATLga chimed in.
