Routing & NAT issue
xfgavin
Hi all,
I requested a binary for ocserv(Openconnect vpn server) from ent-ware and made it running in asuswrt-merlin.
However, I can't make VPN clients NATed to the internet. I am not sure whether it is a iptables nat issue or not. Please advise.
Thank you.
Here is the configuration:
Lan: 192.168.79.0/24
VPN: 172.16.79.0/24
VPN running on port 443 with interface of vpns*
INTERFACES
br0 Link encap:Ethernet HWaddr 38:2C:4A:E3:C2:28
inet addr:192.168.79.1 Bcast:192.168.79.255 Mask:255.255.255.0
inet6 addr: fe80::3a2c:4aff:fee3:c228/64 Scope:Link
inet6 addr: 2001:xxx:xxx:xxx::1/64 Scope:Global
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
eth0 Link encap:Ethernet HWaddr 38:2C:4A:E3:C2:28
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
eth1 Link encap:Ethernet HWaddr 38:2C:4A:E3:C2:28
eth2 Link encap:Ethernet HWaddr 38:2C:4A:E3:C2:2C
inet6 addr: fe80::3a2c:4aff:fee3:c22c/64 Scope:Link
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
ppp10 Link encap:point-to-Point Protocol
inet addr:192.168.79.1 P-t-P:192.168.79.79 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1400 Metric:1
tap21 Link encap:Ethernet HWaddr C2:4E:4E:8F:E9:60
inet6 addr: fe80::c04e:4eff:fe8f:e960/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
v6in4 Link encap:IPv6-in-IPv4
inet6 addr: 2001:xxx:xxx:xxx::2/64 Scope:Global
inet6 addr: fe80::6bb8:3303/128 Scope:Link
UP POINTOPOINT RUNNING NOARP MTU:1480 Metric:1
vlan1 Link encap:Ethernet HWaddr 38:2C:4A:E3:C2:28
vlan2 Link encap:Ethernet HWaddr 38:2C:4A:E3:C2:28
inet addr:xxx.xxx.51.3 Bcast:107.184.63.255 Mask:255.255.240.0
vpns0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:172.16.79.1 P-t-P:172.16.79.196 Mask:255.255.255.255
UP POINTOPOINT RUNNING MTU:1267 Metric:1
ROUTING TABLE
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
xxx.xxx.48.1 0.0.0.0 255.255.255.255 UH 0 0 0 vlan2
192.88.99.1 107.184.48.1 255.255.255.255 UGH 5 0 0 vlan2
172.16.79.196 0.0.0.0 255.255.255.255 UH 0 0 0 vpns0
192.168.79.79 0.0.0.0 255.255.255.255 UH 0 0 0 ppp10
192.168.79.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
xxx.xxx.48.0 0.0.0.0 255.255.240.0 U 0 0 0 vlan2
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 xxx.xxx.48.1 0.0.0.0 UG 0 0 0 vlan2
IP TABLES
:filter
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- 172.16.79.0/24 anywhere
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:443
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:993
DROP all -- 0.0.0.0/0 0.0.0.0/0 state INVALID
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state NEW
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:1723
ACCEPT 47 -- 0.0.0.0/0 0.0.0.0/0
ACCEPT 41 -- 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP)
ACCEPT all -- anywhere 172.16.79.0/24
TCPMSS tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x06/0x02 TCPMSS clamp to PMTU
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
ACCEPT all -- 172.16.79.0/24 0.0.0.0/0 ctstate NEW
ACCEPT all -- 192.168.79.0/24 172.16.79.0/24 ctstate NEW
ACCEPT all -- 172.16.79.0/24 192.168.79.0/24 ctstate NEW
SECURITY all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (0 references)
Chain SECURITY (1 references)
RETURN tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x02 limit: avg 1/sec burst 5
DROP tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x02
RETURN tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x04 limit: avg 1/sec burst 5
DROP tcp -- 0.0.0.0/0 0.0.0.0/0 tcpflags: 0x17/0x04
RETURN icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 8 limit: avg 1/sec burst 5
DROP icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 8
RETURN all -- 0.0.0.0/0 0.0.0.0/0
Chain logaccept (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 state NEW LOG flags 7 level 4 prefix "ACCEPT "
Chain logdrop (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 state NEW LOG flags 7 level 4 prefix "DROP "
:nat
Chain PREROUTING (policy ACCEPT)
DNAT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:9 to:192.168.79.255
VSERVER all -- 0.0.0.0/0 107.184.51.3
Chain POSTROUTING (policy ACCEPT)
MASQUERADE !41 -- !xxx.xxx.51.3 0.0.0.0/0
MASQUERADE !41 -- 0.0.0.0/0 0.0.0.0/0 mark match 0x8000/0x8000
MASQUERADE all -- 172.16.79.0/24 0.0.0.0/0
MASQUERADE all -- 0.0.0.0/0 0.0.0.0/0
Chain DNSFILTER (0 references)
Chain LOCALSRV (0 references)
Chain PCREDIRECT (0 references)
Chain PUPNP (0 references)
Chain VSERVER (1 references)
VUPNP all -- 0.0.0.0/0 0.0.0.0/0
Chain VUPNP (1 references)
:mangle
MARK all -- 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
MARK all -- 0.0.0.0/0 xxx.xxx.51.3 MARK or 0x8000
Chain FORWARD (policy ACCEPT)
MARK all -- 0.0.0.0/0 0.0.0.0/0 state NEW MARK xset 0x1/0x7
