FTC
Hello,
I recently purchased the subject repeater RP-AC68U (real cheap, second hand) to use it as a repeater near my TV set and communicating in expressway 5Ghz mode to my RT-AC3200 for high speed comms and being able to feed data to several electronics (PVR, IPTV deco, XBOX...) thanks to its integrated switch. In general terms I am quite happy. Performance is solid and high speed, but I've found several nits. I am working with latest firmware for the RP-AC68U : 3.0.0.4.382.10513. Has anyone found this problems before ? is there any way to circumvent them ?
- 1) The apply button of the 'IPTV' tab in the LAN section of the GUI does not work (does nothing), so I can not enable IGMP proxy to make my IPTV comms more efficient. (and probably related to not being able to detect the DLNA servers of my network some times)
- 2) I have setup a wifi schedule so that the 'repeated' wifi signal is switched off during the nights. It seems like this is not working properly and some times not switching off wifi when it should.
- 3) There is no way in firmware to see if the wifi signal is up or down..
- 4) There is no way to identify in the clients list which clients are in fact connected to the 68U or to the 3200. It seems like showing all clients for which any kind of traffic passes through the 68U
Does someone have any news on a future firmware that may fix those ?
