RT-AC68P Firmware Upgrade Issues
whitedollarpen
Hello all,
I have been having trouble upgrading the firmware on my ASUS RT-AC68P router. It is currently on Merlin's 3.0.0.4.376.49_2 version. I am currently running Windows 10 and have tried unsuccessfully to upgrade my router through IE, Edge, and Firefox. I upload the chosen firmware .trx file and it will go through the "upgrade" process up to 100% where it says "Completed" it then kicks me back to the homepage but the firmware is still at the same version. I have done multiple factory restores/resets through the web interface and through the button on the back. I have tried both Merlin and ASUS OEM firmware, as well as having tried both wireless and wired. I do not know what is going on? Has anyone had a similar issue?
This was asked and answered many times recently a small search would help... :rolleyes:
Pls. read the chang log and look for CFE update! :eek:
Update to the version with the CFE update first and then to the recent one.
With kind regards
Joe :cool:
With kind regards
Joe :cool:
Thanks, and apologies. I have been out of the scene for awhile and didn't presume this was a common issue.
This is actually a bit more interesting. I thought that all the recent Merlin builds contained the CFE update, so that a step update wouldn't be necessary. Maybe I'm mistaken?
I had the same understanding, but it seams that with the recent build people have issues if they come from a 40s version... :rolleyes:
Would I be correct in assuming that the implied step update is 378.50 and then I can go up to 378.56_2?
Correct! ;)
But keep in mind that the new CFE will also repartition the flash and you will loose /JFFS - so better do a backup!
It should still be there, unless Asus changed that code. Since it's closed source (cfe.o), I have no way of knowing.
If that's the case, we'll have to track a known good release (beside Asus's last 376 release which will eventually disappear from their website), for future reference.
