A Chinese AC86U has only two GUI languages options, English and Chinese.Hello,
can you clear to is the Merlin FW support RT-AC86U bout form china ?
any issue with this prodact ?
its look the same but ... i never know
thanks that great , i will try itAs long as it is a genuine Asus router, regardless of the country.
AFAIK, Asus uses the same firmware across all countries.
You could step over, only need to use url for main page or network overview where you directly can change the language: 192.168.50.1/index.asp or router.asus.com/index.aspOnly (big) negative of the Chinese version, after a factory reset or firmware restore the following 3-4 panels on power-up are all Chinese, needed to be completed, before you can get to the panel to flip language from Chinese to English. Wireless (professional) gives you channel 12/13...I change back to North America setup as in Canada.
Welcome To SNBForums
