Script Recommendations
johnathonm
Hello,
I hope you are all well. I wanted to reach out to the forum to see if you all had any scripts and/or script recommendations you would be willing to share.
I am currently using the three big ones that I came across in the forum: the two from Lonelycoder (Ab-solution his terminal script) and Skynet. I am sure there have to be more or scripts others have written for their personal use.
If you would be willing to share or make some recommendations that would be great.
Thanks in advance.
J
Hello,
Thanks in advance.
J
Install "AMTM" it will help with Dnscrypt and others.
Skeal,
Got it.
-J
Hello,
Thanks in advance.
J
For those with mips routers I would add ya-malware-block.sh to the list.
