Seth Harman
After participating in a few threads regarding Guest Network Pro/VLANs I've discovered I'm still a bit confused as to what Asus is doing. In regards to VLANs here's what Asus says:
1). By creating a Guest network pro, a VLAN will be created as well in VLAN settings.
2). VLAN supported models:
They also have this on their site:
Product RT-BE58U, RT-BE92U, TUF-BE3600, TUF-BE6500, ZenWiFi BD4 Outdoor, ZenWiFi BQ16, ZenWiFi BQ16 Pro, ZenWiFi BT10, ZenWiFi BT6, ZenWiFi BT8
[Wireless Router] What is Smart home master?
ASUS Smart Home Master is a revolutionary tool for seamless network segmentation, enhancing both security and flexibility. With the ability to create up to three SSIDs, it simplifies complex subnet configurations, making it effortless to customize your network for children's devices, VPN connections, or IoT protection.
So it would appear they've now renamed the old-style Guest Network system as "Smart Home Master" (or maybe it was always called that and I just didn't notice) and VLANs as "Guest Network Pro"; this would explain why my RT-BE58U AiMesh nodes don't show up on the VLAN page of my RT-AX88U Pro to allow me to set up the physical LAN ports as trunk/access ports as they don't have native Guest Network Pro support.
So here's my question: Can anyone clarify if this is due to limitations of the hardware being used in these various Smart Home Master-compatible models listed above or is it a business decision by Asus to reserve Guest Network Pro/VLANs to their "Pro" routers [Caveat: there's several models that support GNP/VLAN that aren't called 'Pro' in their names]? For example, the RT-BE92U is a newer-model router that's attractive as it has tri-band capability but doesn't show as having GNP/VLAN support, and the WiFi 7 models currently available that do support it are considerably more expensive and from what I've seen several of them don't support tri-band. It seems like an odd mix of what supports GNP/VLANs and what don't.
- GT-AX11000 Pro, GT-AXE16000, GT-BE19000, RT-AX88U Pro, RT-AX86U PRO, RT-BE96U, RT-AX57 Go, RT-BE88U, RT-BE86U, GT-AX6000, GT-BE98, GT-BE98 Pro, GT-BE96
- ExpertWiFi : EBG19P, EBM68, EBR63, EBG15, EBA63
