Simplest QoS option
Fyuqod
On 50 mbit fibre connection. I just need to always have minimum 10 mbit up/down and max 50 mbit per client. There will never be more than 5 competing for the bandwidth, if even that.
I looked at the options but there was just a hard limit or prioritize certain services. AC86U running merlin.
Regards.
dave14305
Part of the Furniture
I was going to suggest just using Cake without any addons or mods. You’ll get per-host fairness on the LAN, without wasting bandwidth.
Fyuqod
Thanks guys. Trying Cake now with 95% up/down and default on the rest. Working great so far on my stress tests
Fyuqod
I saw wired a bit too late :) I can do that tomorrow.
Uncrowded 5Ghz, managed to get A+ constantly with 49mbit/49mbit setting.
With 50mbit/50mbit gaming under load didn't pass every time
I don't know why the download speed is in the low 40s. On speedtest.net I get 47 mbit with 49 mbit setting
Lynx
Looks really nice to me. I wish I had such a connection. Instead I have an LTE connection that swings between 30 and 70 Mbit/s. That, and VPN, makes getting CAKE to work well rather a challenge. Fortunately with custom scripts dynamic bandwidth / VPN is manageable.
Fyuqod
Yeah it works great.
@Lynx make sure to get a proper LTE antenna. You can even have it indoor. I got a Poynting xpol-2 (SMA connector) . Speed will of course vary but the connection will be better. Pm me if you have any questions.
Morris
Regards.
To meet that goal, you do not need QOS as the worst case is all devices doing a file transfer at the same time in which case each device would get 1/5 of your 50 Mb link which is 10 Mb.
Morris
