bwana
2 pcs connected by cat 6 cable an gigabit switch (cable runs 20 feet, new netgear switch)
(opteron @3 ghz,2 gig ram, gigabit NIC on mobo, windows 7 pro 32 bit)
(core i7 920 @ 4ghz, 6 gig ram, gigabit NIC on mobo, windows 7 pro 64 bit)
8 gig file transferred from one pc to another.
Transfer starts out strong an peters out to 1.5 megabytes/s.
Removed remote differential compression on both machines.
Disabled autotuning on both machines.
Transfer starts out much stronger (~100% network utilization!) but then peters out to 3 MBs/s
It wants an hour to transfer an 8 gig file! Shouldnt this transfer be faster? How can I diagnose the problem?
iperf shows 503 Mbits/sec with an 8 k window size and transferred 601 MBytes. shouldnt this be closer to 900 Mbits/s?
well, setting the tcp buffer to 65000 gets me to 98%utilization so it seems that if i want my transfers over the LAN faster I need to manually make the window bigger every time I drag a big file from one box to the other. but for internet stuff, that window is too big. is there a way to make the buffer bigger for LAN only transfers?
