Stop inter VLAN routing ?
probably best to keep things on that thread...
quick answer, and we can discuss more there - if you have a member that is part of two VLAN's, you can get into a situation where you have an implied route across those two, and it won't be immediately obvious.
Thanks for the reply. I asked here incase it was an Asus specific issue.
I'm happy to listen to any advice you have.
Thanks.
