Stephen Becker
I have two houses that each have ASUS routers and I want to make both LANs routeable. The concept is this, setup a tunnel between the routers, add a static route on each router pointing to the other's LAN network, using it's tunnel IP as a gateway. I work with Cisco routers a lot and such a setup would be easy as cake on them.
The two issues I ran into using the factory firmware are
--No way to statically set the tunnel IP address of the client router
--The client router seems to use NAT to access the tunnel, I don't want NAT, I want direct routing
Does the Merlin firmware allow me to make those two changes I would need to make (statically set the client VPN's IP address and disable NAT for the tunnel)?
I read that Merlin adds IPsec support, which would be the easiest, but I don't have static IP addresses and you can't add hostnames to a routing table. Instead I was hoping to use OpenVPN to establish a GRE-like tunnel via DNS lookup, so I can put the virtual tunnel addresses in the routing tables.
