wan access issue (?)
aksufun
Hello guys, I'm setting admin access settings on my RT-N66U (3.0.0.4.372.30_3 (Merlin build)) as shown on the printscreen (look at the "Enable Web Access from WAN - NO" point) but still can connect to my device from WAN.
What I do wrong?
Expected behavior - when I choose "Enable Web Access from WAN - NO" anyone should not be able connect to my device from WEB.
Its corrent or I'm wrong?
Thx for any advice.
Found your problem, update to a later release as there isn't an issue with the current version.
Big thanks for fast reply!
Is it also fix the same problem with SSH?
with this settings I still can connect through SSH to my device
P.S. I didn't find any occurence about my problems in Merlin changelog thats why I'm asking.
Make sure you have the router firewall Enabled, as well as NAT. Otherwise, half of these firewall-related functions won't work as expected.
