What does ”[tdts_shell_ioctl_stat256] Recv ioctl req with op 2” mean?
D
Deleted member 91178
Guest
I got hundreds of the following messages in my router log yesterday:
”crashlog: <7>[tdts_shell_ioctl_stat256] Recv ioctl req with op 2”
What does that message mean?
It's caused by one of the trendmicro apps. Withdraw your consent in administration>privacy and it'll disappear.
However, if it's not causing any problems (likely) then it can be ignored.
I see! Thank you. I have never seen this message before, and yesterday I recieved more than 400 of those in a row. Does this indicate some sort of attack? Something I should worry about?
Like I said, if it's not causing problems (like WAN or WiFi disconnects, etc) then you can just ignore it. The rate you describe would indicate something like the Traffic Analyzer, or the Classification tab in QoS.
It seems like this occurred during a crash and some sort of recovery. I did not notice anything but the logs suggest that a reboot occurred with alot of other crashlogs. It just got me worried that my router had been infected with some kind of malware.
