I need some advise, which router for me.. needs below
I do have two internet connections and i´d like to use second as fail over.
- Dual WAN with fail over (no need for a "load balance")
- Gbit ports (LAN/WAN) 3 LAN is enough if one will be used for WAN2
- Cheaper than Asus RT-AC68U. It´s too much for a home router..
- WIFI minimum is n class
- DD-WRT or some other 3rd party firmware with GUI Ok.
