Wired speed/duplex issue
paradeedle
I added kamoj's information addon to my Nighthawk X4S and noticed an odd speed/duplex issue showing for my wired connection:
Port Status WAN:1000M/Full, LAN0:10M/Full, LAN1:1000M/Full, LAN2:100M/Full, LAN3:Link down
LAN0 is another router setup for VPN access. I checked that router(running DD-WRT) and it is showing 1000M/Full. I have no idea why it is showing 10/Full on the X4S. Any idea why the X4S is negotiating at 10M/Full?
RMinNJ
I dont run that add on but... what color is the link light on the X4 (7800) for that port? I know my Roku connects at 100Full and the light is amber instead of white.
The LED color indicates the speed: white or green for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
paradeedle
I have the LEDs turned off except for the power LED.
It turns out I'm just dumb. I was tracking down wires and LAN0 was actually my PC that was turned off. Apparently it just auto-negotiates to 10M/Full when it's off. I turned on that machines it is showing 1000M/Full again.
Disregard
