Hello!
I have 2 Asus RT-AX92U devices set up in an AiMesh configuration, and over the last week I have noticed no wireless clients are connecting to my Ai node, everything only connects to the main router. I have the node set up with an ethernet backhaul, have Smart Connect enabled for Tri-Band, I have played around with roaming assistance, and still have no luck getting wifi devices to connect to the node. Firmware is current (3.0.0.4.388_22525), but the problem started before I updated the firmware. I have tried to disconnect clients manually and attempted to reconnect in close proximity to the node, and it still goes back to the main router. I just completed a factory reset on both routers and set them up again, but the problem continues.
Before I go the route of replacing the system, anyone else experience this problem and have a fix for it?
Thanks,
JT
Thanks,
JT
