For some reason when I set the wireless ssid for 5g and 2.4g they change back to what they had before.
So I set them the same at first and then I wanted to change them so as I could ensure that the pc upsatairs was connecting to the 5g. So I deleted both and went through the network set up again and gave them different ssid's and all seemed to work fine but today they have reverted back to the previous settings. I carried out reboots after the deletion and the change.
The strange thing is that it's not a permanent change it seems to flit back and forth from the old one to the new one. I am supposing a major change like this would maybe require a factory reset of the router??
If so could somebody point me in the correct direction of properly flattening the router.
