anotherbrian
Having troubles using my work VPN from my home. It works if device uses wifi direct to xfinity router but will not work as I desire. I desire all devices to connect via my tomato home router with the home router hardwired to the xfinity router and no xfinity radio transmissions polluting my environment.
According to xfinity website, for a user to connect to a vpn, the user must connect (via wifi) to their router or their router must be configured as bridge mode.
Xfinity Bridge Mode Unreliable
In bridge mode, a wifi connected device to the home router is able to access the work VPN. Unfortunately, widely reported is a problem with bridge mode where the xfinity router stops communicating with the home router. Attempts to get the lease renewed from the home router shows "renewing" but does not get the new lease. Later it may successfully renew or it may go on for hours. Rebooting the home router results in success but the issue may repeat after several days or it may repeat many times in a day. So I stopped using bridge mode.
Xfinity Non-Bridge Mode VPN won't work if wifi through Home Router
The device will not connect to the work vpn if the device connects to the home router via wifi. What is it in the xifinity router that blocks vpn connections? VPN works if the device connects direct to the xfinity wifi. My goals here are to have all my home devices connect via my tomato router and have no trace of xfinity radio signals.
I probably am able to isolate the bridge mode issue but I would need to do some digging to find that old bridge and learning wireshark.
Can the xfinity router dmz function be used to allow vpn connection via home router?
Is this a plot by xfinity to force people to use their wifi?
thx for suggestions / reading
