Solved aaews open two port random
Miguel
Hello, first of all, apologize for my English.
I tell you my situation.
I don't have much router experience.
I currently have the following connection.
ONT --> RT-AX82U(Firmware:388.2_2_0-gnuton1) 192.168.2.x --> Lan4 to wan port RT-AC66U B1 192.168.1.x ( Firmware:386.12)
static wan port 192.168.2.100 and 192.168.1.x this router, when I deactivate the RT-AC66U B1 firewall so that the RT-AX82U network can see the RT-AC66U B1 devices defined in the static route, 2 ports open that are exposed to the internet the service is aaews, the truth is I don't know what it's for, if I restart the router those 2 ports change for other random ones, I'm worried that two ports that I don't know what they're for will be exposed to the whole world.
I understand that aaews is for saving logs? But because by deactivating the firewall on the 2 router it exposes me to 2 ports to the public IP.
DMZ on 192.168.2.100 which is the wan of RT-AC66U B1
578 574 xxxxxxx S 10504 4.1 0 0.0 aaews --sdk_log_dir=/tmp
581 574 xxxxxxx S 10504 4.1 1 0.0 aaews --sdk_log_dir=/tmp
586 574 xxxxxxxxx S 10504 4.1 1 0.0 aaews --sdk_log_dir=/tmp
580 574 xxxxxxxxx S 10504 4.1 1 0.0 aaews --sdk_log_dir=/tmp
574 531 xxxxxxxxxxxx S 10504 4.1 1 0.0 aaews --sdk_log_dir=/tmp
575 574 xxxxxxx S 10504 4.1 0 0.0 aaews --sdk_log_dir=/tmp
tcp 0 0 0.0.0.0:33622 0.0.0.0:* LISTEN 531/aaews
tcp 0 0 0.0.0.0:33623 0.0.0.0:* LISTEN 531/aaews
udp 0 0 0.0.0.0:33622 0.0.0.0:* 531/aaews
