AC88U system log flooded
lordtech
Hey there, I've been running FW386.1 on RT-AC88U since it came out, and just in the last few days I have started receiving the following message in log files:
Feb 10 11:03:39 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:03:39 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:07:24 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:07:24 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:08:11 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:08:11 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:14:58 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:14:58 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:33:10 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:33:10 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:34:03 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:34:03 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:35:36 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:35:36 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 10 11:40:04 RT-AC88U kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 10 11:40:04 RT-AC88U kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Is anyone having the same message? Is this message a standard one or is telling me that I have an issue?
Thanks in advanced!
BrettDioson
Same issue for me on an RT-AC5300. dirty upgrade to 386.1_2:
Feb 15 11:32:50 RT-AC5300-AD60 kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 15 11:32:50 RT-AC5300-AD60 kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Haven't seen anywhere else on the forum on what causes this, but a few people have posted about it in the 386.1 release thread.
lnViztor
In my case I still have errors of that type. I don't know if mentioning the developer in this thread can still help us. In my log also transmission gives me an error. I think everything comes from my HD connected to USB. I will try to remove it to see what happens.
Feb 16 09:18:17 RT-AC88U-F018 transmission-daemon[2466]: Unable to create session lock file (22): Invalid argument (session-id.c:96)
Feb 16 10:27:10 RT-AC88U-F018 kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 16 10:27:10 RT-AC88U-F018 kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Feb 16 10:44:55 RT-AC88U-F018 kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Feb 16 10:44:55 RT-AC88U-F018 kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Wishmaster1965
I am getting the same after a dirty update to 386.2 on my RT-AC88U.
L&LD
Part of the Furniture
There is no RMerlin 386.2, yet.
Wishmaster1965
lordtech
386.1_2*
It seems that these errors in most cases occur on the ac88u model. ¿Any solution?
I was about to comment the same but BrettDioson has another model. Anyway, I will do a full restore procedure during the coming weekend to see if I can eliminate these messages
lnViztor
Yes, it seems that in the 3200 it also happens. In your case and mine we have the same devices (AC88 + AC68 node). I did a clean install thinking that it would be fixed but I still have those entries.
lordtech
I did finally a hard reset and configure it all over again, and I've uploaded again the firmware (386.1_2) on my AC88U. I installed some scripts such as amtm, diversion and skynet, and I did not face any message for many hours (12 hr. more and less). After that I installed scribe and then I started to see the same messages in my log.... :(
I am pretty sure that scribe has nothing to do with the problem......
Wishmaster1965
I did a factory reset 2 days ago and now these messages are re-appearing on the 3rd day
lordtech
lordtech
Yesterday I uploaded the firmware 384.19 back from firmware 369.1_2 in my router and node, and I am not getting those messages so far (I did a dirty downgrade so same configuration)
Also, I am not experimenting AiMesh nodes disconnections as I was having with firmware 386.1_2 (AiMesh nodes disconnect since 386.1)
Let see the behavior of my connection in the coming days.
ComputerSteve
My log is also flooded with these messages -
Mar 24 07:35:56 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:35:56 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:35:57 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:35:57 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:37:27 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:37:27 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:37:28 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:37:28 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:37:55 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:37:55 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:38:57 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:38:57 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
